FE Power Forums => FE Technical Forum => Drag Strip Results for FE Powered Vehicles => Topic started by: jayb on May 06, 2015, 08:54:58 AM
Performance Summary:
1/4 mile ET: 10.55 1/4 mile MPH: 129
1/8 mile ET: 1/8 mile MPH:
60 foot time:
Track: Gateway International Raceway, St. Louis area
Weather Conditions: Hot!
Vehicle Specifications:
Model Year: 1969
Model: Mustang
Style: Mach 1
Engine Details (link to post in Dyno Results board if available:
http://fepower.net/simplemachinesforum/index.php?topic=2675.0
Transmission: Performance Automatics C4, full reverse manual valve body with trans brake (brake not used), Gear Vendors overdrive
Torque converter details (if automatic): Neil Chance 10" converter, "almost" locked at 2500 RPM for good street performance, fully locked at 4000 RPM for drag use
Clutch details (if manual): NA
Driveshaft: Mark Williams chrome moly drive shaft
U-joints: Mark Williams 1350 U-Joints
Rear end type: Ford 9", factory housing with reinforced spring perches, Mark Williams aluminum center section, aluminum pinion support
Differential type: Detroit locker, old style that clicks around corners
Gear Ratio: 4.11
Axles: Mark Williams Masterline 31 spline
Front tires: 225-60/15 Goodyear street tires
Front wheels: Magnum 500 15X7
Rear tires: Mickey Thompson 9.0 X 28.0 ET Drag Tires
Rear wheels: Magnum 500 15X8
Front suspension information: Small block front springs (one coil cut off to lower front end), front sway bar removed, Competition Engineering 90/10 shocks, rollerized spring perches
Rear suspension information: Cal-Trac traction bars set in lower hole, 1/2 turn preload on driver's side, monoleaf springs, Rancho shocks
Ready-to-race vehicle weight, including driver: 3600 pounds
I find your weight interesting. I've been trying to pay more attention to weight as I gather stuff for my own drag car.
My Mach weighs 3460 pounds. Add me to it and it puts it right at 3600, the same as yours (done on state calibrated scales). Yes, I'm a light person despite being 6' tall ::)
Our cars are very similar in build as far as the drivetrain, but with a few differences. I have iron heads, dual carb intake, toploader and a factory oil cooler, not to mention extra sound deadening added to the entire interior and under the front fenders (to stop stones from denting the tops of the fenders, which a friend found out the hard way), probably adding another 25 pounds just in deadener. All these things would presumably be heavier than what you have on your car, although I'm sure your Gear Vendors OD unit would pretty much equal out the added weight of my 4spd and related hardware.
The only equalizers I can come up with are the rims, you having factory steel and mine being aluminum. My rear rims are VERY light and my fronts are pretty skinny compared to your wide steel rims. That's a lot of weight equalizing given the extra weighted items on my car.
Can you think of anything else that adds to the weight of your car, Jay?
Edit: Dang, as soon as I posted that, I remembered you have a full roll cage and I have nothing. I assume that would equal it out right there.
Back in 2005 the car just had the NHRA roll bar, but it was not chrome moly, it was the heavier .134" wall DOM tubing. It weighed right about 100 pounds (I weighed it as I was installing it), and interestingly enough with chrome moly tubing the full cage in the car now is also right about 100 pounds. The aluminum block and heads save some weight, and the driver (245) adds some LOL! The steel wheels and 235/60-25 front tires are really heavy too, and back in 2005 I was running tubes in the slicks making the rear wheel combination pretty heavy also.
