FE Power Forums => FE Technical Forum => Topic started by: preaction on August 25, 2017, 11:12:41 AM
Can anyone point me in the direction to purchase these and a new damper spacer ?
I think Precision Oil Pumps still sells 'em.
Summit has cylinder head dowels:
https://www.summitracing.com/search/make/ford/engine-size/6-4l-390/engine-family/ford-big-block-fe/department/engines-components/part-type/cylinder-head-dowel-pins?N=4294951343%2B4294948007%2B4294948006%2B4294949512%2B4294867396
As already mentioned, POP has new harmonic balancer spacers. But Summit has Speedi-Sleeves if you have a worn unit.
https://www.summitracing.com/search/make/ford/engine-size/5-9l-360/engine-family/ford-big-block-fe/department/engines-components/part-type/harmonic-balancer-repair-sleeves?N=4294951343%2B4294951326%2B4294948006%2B4294949512%2B4294859677
Thanks. I found an aluminum spacer made by Blue thunder and sold by Dennis at DSC.
Head dowels are same as the 429-460.
I wouldn't use aluminum, unless it was VERY hard anodized. Otherwise the seal will actually wear it down....
I just ordered a set on epay. About 6 bucks. You can also pick your other items there if non of the site sponsonsors can't help you.
I wouldn't of thought that thanks Brent.
Barry shows a pic of a black one in his book Im guessing its aluminum.
You could get them from NAPA, not sure if still available. If anyone ever needs the NAPA part number I can get it from the shop.
My napa said no even in a much later 460 application.
It has been a while since I ordered any, but I usually find on this older stuff I have to give them the part number. I still have catalogs so I just went and looked it up. It's part # 600-1611 Balkamp. Have them try that number. It may have been discontinued but I'm sure they wouldn't find that number in the computer...
Pioneer head dowels for FE's and big blocks are all over ebay and Amazon. $6.oo a set and free shipping in some cases.
"Pioneer Cylinder Head Dowel Pin S-1113"
Amazon, ebay, Summit, etc...
$2.99-$5.00
As above, keep a box on the shelf and never have to re-use any of the dowels.
