FE Power Forums => FE Technical Forum => Topic started by: 67428GT500 on January 15, 2019, 02:53:22 PM
I was curious what the OE 427 cam specs were. I noted many vehicles had power brakes with the 427. What kind of vacuum did the factory cam produce?
-Keith
Here is all I got
The C3AZ-AA I believe is what was delivered from the factory and you probably could run power brakes with that. 306 duration, .500 lift, 78* overlap
I'm not sure the C4AE-B was only over the counter or not. 324* Duration, .500 lift, 112* overlap
I know the C4AE-B didn't have much Vac. in my 406, maybe 12 inches was the best, that was back in the day with 12 to 1 comp. That cam sure sounded good, idled about 900 with a 4 speed. A wide ration Trans or tighter gears would have made for better drivability with a 3800 lbs car.
And the big C8AX-D was definitely not going to satisfy power brakes 330* duration, .600 lift, 116*overlap
These numbers are factory specs (not at .050)
I have my custom grind. I was just curious what the specs were as they supported power brakes, which needs about 16 inches of vacuum to work.
I wouldn't count on a 'Double A' for power brakes. And I believe the only 427s that came with power brakes were the juice lifter ones that came in the Mercs. I believe they came with GT or perhaps CJ cams.
Several 427 cars came with power assisted brakes. My cam isn't that radical, but enough to lower the vacuum to about the minimum that a Midland-Ross booster will function with. I was just curious how the OE 427 cam compares with what I am running.
-Keith
-Keith
Which 427 cars came with power brakes? Not doubting you cuz the "AA" cam would work ok with them but I just never heard of that combo.
Several 427 Cam grinds:
The "AA" cam from the 352/360hp 390/275hp 390/401hp 406/385hp 406/405hp 427/410-LR (maybe the 427-MR too, conflicting info)
228-228-114.5 at .050, maybe 14-15" vacuum at idle, works fine with stock stall automatic & power brakes.
The c3az-k cam, I've heard it called optional but also that it was stock on the 427-8v-LR:
244-244-114.5 at .050, maybe 8-9" vacuum at about 700-800rpm, marginal w power brakes, "good for one stop" anyway. I've run this cam with power brakes for years. It was the wildest production cam.
c4ae-b cam, factory stock on the Thunderbolt and LWG cars, if you call that production.
244-244-106 at .050, same as previous cam but a LOT wilder with the closer centers. I doubt if power brakes would work.
c8ax-d cam, factory stock on the 67-69 Tunnel Port factory Fairlane cars. Oh wait, there weren't any.
272-272-107 at .050, but you wouldn't want power brakes on that car anyway.
Finally, the hydraulic 427 of 1968 used the 390gt/428cj cam at
207-220-116 at .050, so smooth you can barely tell it from the vanilla cam, maybe 16-17" vacuum.
I'm pretty sure these came with a power brake option but I never heard of any other 427's offered that way.
