FE Power Forums => FE Technical Forum => Topic started by: fekbmax on December 01, 2015, 06:25:52 PM
Cylinder wall finish for moley rings, ? What's your guys thought's.. ??
http://www.enginebuildermag.com/2004/05/cylinder-bore-refinishing/
I used a 320 grit Flex Hone to put in a fresh surface for moly in the 351C for the Mustang. The bores were straight, just wanted a little fresh surface for ring seat. I did buff the bores a bit with green scrub pads, then washed them extensively. Rings seated immediately, no oil use.
