FE Power Forums => FE Technical Forum => Topic started by: Jb427 on February 27, 2022, 09:31:53 PM
Got a call from my gearbox builder today letting me know he can't get the valve body i need dose any one know a good place to try for a full manual valve body for a early model case C6
I don’t have any personal experience, but most people I’ve seen comment on the internet seem to recommend Frank Merkl for C6 valve bodies. This is the last contact info I have for him.
(https://i.postimg.cc/7Y86nV1S/2240-BAA5-3-A7-C-4232-A141-A17140-BDD1-AD.jpg) (https://postimg.cc/yWjsV0bN)
Call Jay at Broader , Frank Merkel is a great C6 builder too , he's a Farmer and might not answer the phone when you call , Frank figured out TCI's slow to shift into third on the TCI manual reverse valve body with Brake
https://broaderperformance.com/product-category/vavle-bodies/ford-c6-vavle-bodies/
By "Early model case", do you mean a 66 only case? I understand that the 66 valve body is an oddball, but if replacing the actual valve body itself, wondering what the issue is? If you mean the style of spring loaded shifter detent design, years ago, when I installed a Ford Motorsport/Art Carr full manual, reverse pattern valve body, I ran into a situation, where there was an issue with the valve body setup for the leaf spring roller detent on the inside shifter lever, but my case was the other style, which had a detent spring in the valve body. The other style VB had the provision for the detent spring, so I just swapped the spring and pin from my stock valve body, into the new VB. Worked just fine.
It is 67 and it has the detent in the valve body im not sure if there was a early and late for fe c6's early being detent in valve body and late being in case.
Thanks for the help people
X2 on calling Broader Performance
Transgo 67-3 is a full manual forward pattern valve body kit that works great .It will work with your early valve body that has the detent in the valve body .It isn't hard to install and you can convert it over to automatic shifting with the extra parts in the kit .Doug
coan engr. trans&convert have been around 25 years - supply parts for builders too - i believe- work good for me IN-765-456-3957 todd ext 218 - knows c-6 everyone - good luck finding 2022 parts! john-oldiron
