FE Power Forums => FE Technical Forum => Topic started by: fryedaddy on October 01, 2019, 11:53:10 AM
my red light on my box wont light up and engine wont start.is it shot?
Check to see if it's getting power...12V.
I don't care for MSD products and still using my old Crane HI-6 unit!
If it crapped try this 1, all the new boxes from msd are china made.
https://www.summitracing.com/parts/tay-401001/overview/
i have been running this box for about 2 years now.i guess it shot its wad.i may send it in for repairs and buy a new one and carry a spare in the trunk.luckily it quit in my garage instead of off somewhere else
Thanks for that link. I did not know.
i wonder if the taylor box uses the same plug and harness as the msd.if i bought a taylor and get my msd repaired to keep in the trunk,it would be nice if they both would plug in with the same harness
I am using this in my Comet. Check out the features for the money. I have only used it for this summer so I cannot attest to the reliability. It has good reviews and works great for me. I love launching off the 2 step!!.
https://www.summitracing.com/parts/pnx-510
Yes the taylor cd box hooks rite up an msd dizzy
are you saying if my msd fails while driving,all i have to do is plug in the taylor box to my existing plug and harness of the msd box
Fryedaddy that is correct ,it is the same 1 piece plug in as the 6Al.
It had me curious so i tried it and fired up my 65 f100 to confirm that it work's.
Yeah, 20 years ago MSD was possibly the best. Not anymore from what I here. Dang.
JMO,
thank you Mr CattleFEder.
JMO,
Sure seems that way. I have had the same old MSD 6T ignition box for about 25 years now, still works great, although the 6T does require a seperate rev limiter. When the analog 6AL came out, I bought one, and installed it in my 85 Mustang Stock Eliminator car. During the next 10 years, I had 2 6ALs fail on me, while the old 6T keeps going and going......
update-i had my son, the electrician in the family take a look at my ignition.he found that my red wire to the box was chewed by a mouse.after fixing that the box started working again but it was running rough and backfiring when i tried to rev it. i remembered the last time i drove my comet i got caught in a rain storm.my hood scoops are open so i thought i would look for moisture in the dist cap.so after spraying it off with wd40 inside and out,i wiped it off and put it back together.its now a screaming S.O.B.that shows me what the instruction book says that most of the time its a ground or loose connection instead of box failure
^^^ Glad you got it fixed. Electrical issues can be a major headache.
Two weeks ago I got the ride of shame home on the flatbed. Was running round with my son enjoying the weather and stopped to top off gas prior to going back home. Hopped in and no electrical at all. No dome light.. no horn.. no ignition.. no dice. WTF! Thing was running fine 10 minutes before. Batt.. cables and fuses all good. /scratch-head
Long story short. I've owned this car 25 years and never noticed the previous owner had taken the 2 wires from the hot side of the firewall solenoid and combined them with a 3rd. Hooked them together with a small screw, electrical taped the entire setup up & hidden it under the battery tray. The 3rd wire went through the amp meter on the aftermarket Sunpro 3 gauge set and back to the hot side of the solenoid. So all the 12v electricity (interior and ignition) was going through the amp meter! Found it when I was chasing the circuits back with the schematic. Guess I should be thankful it farted out closer to home and not at a meetup a hundred miles from home. :o
i have owned my comet for over 36 years.back in the 80s and 90s when i ran points dist and stock coil,it never crossed my mind that my ignition might burn out miles from home.i used to drive it to the beach back then,1000 mile round trip and never worry about failure.now i would be afraid to drive it that far without a backup
I run a duraspark and a MSD box. I keep a point distributor in the trunk
so i can drop it in if the electronics fail
