FE Power Forums => FE Technical Forum => Topic started by: billtroth on April 13, 2018, 03:47:30 PM
I'm rushing to get my car ready for the FE Reunion and hit a snag. I n adjusting the valve lash on my Dove rockers I found one of the adjusting nuts is cracked and the 5/32" allen key won't turn it. Has anybody run into this and know a fix? I bought three new rockers from Dove about a year ago and they have 1/8" female hex so I believe the cracking of the 5/32" has been a problem. I tried heating it with a hot air gun and that doesn't help. I'd welcome any ideas. I attached a picture file and the crack can be seen on the left side.
Looks like you have enough threads there to run another nut down on it, tighten the 2 nuts together then wrench it out from the bottom nut.
Thanks. I have to go "down" since the ball end of the adjusting nut will not clear the hole in the rocker. I did finally get it to move bu using two jam nuts but it was a challenge.
