FE Power Forums => FE Technical Forum => Topic started by: jayb on December 28, 2014, 10:28:28 PM
I've been threatening to run this test for a month, but keep getting sidetracked. Finally got around to it today. The dyno mule is my trusty 428 Cobra Jet, now fitted with one of my prototype timing covers, and a Rollmaster timing chain which I've modified to allow cam timing changes at the top gear. See the FE Timing Cover topic in the Member Projects section for more information on this.
The cam in this engine is a Comp 294S solid grind for the FE. Lobe separation angle for this cam is 110 degrees, and I installed it 3 degrees advanced, at 107 for the intake centerline. The conventional wisdom of cam timing is that advancing the cam improves low and midrange performance at the expense of the top end, while retarding the cam improves the top end at the expense of the low end and midrange. The idea behind this test is to check this out. Most of the time the "conventional wisdom" can be suspect, so I wanted to see if it held true on this engine, while also taking the opportunity to check out the utility of my timing cover and timing gear setup.
Because of limited time, I decided to just test the cam timing at the straight up position, and also advanced and retarded 6 degrees. So, In addition to 107, I was going to check the cam timing at 101 and 113 for the intake centerline.
After running the engine for about 20 minutes to warm it up, I ran the first pull as a baseline, and then took a good look at the timing cover to see how it was faring. I was happy to see that there didn't appear to be any leaks around the removable cover plate, so apparently the O-ring was doing its job. I had also fitted this timing cover with the 351C front seal, and machined a longer sealing surface on the crank spacer. This also appeared to be working well, as there was no evidence of any front seal leakage.
Next I turned the engine over by hand to TDC on the #1 firing stroke, and took apart the front of the engine to get at the cam timing adjustments. Of course this was a lot easier on the dyno than it would be in the car, but even on the dyno I was surprised at how easy it was. I was using my electric water pump adapters and the CVR pump, and these use O-rings to seal to the engine block, so after draining the water from the dyno's cooling tower I just pulled the four water pump bolts to remove the pump, while the water from the engine drained into a pan below. No gaskets to mess around with, which was nice. Next I loosened the one timing cover bolt that holds one end of the timing pointer, and removed the 10-32 screw in the removable timing cover plate holding the other one, and the timing pointer swiveled out of the way. Then I pulled the six bolts holding the removable plate onto the timing cover, and off it came. Here's how it looked at this point:
(http://fepower.net/Photos/Posts/eccentrc.jpg)
Next I removed the fuel pump and the fuel pump eccentric and cam bolt, to expose the timing holes in the cam gear:
(http://fepower.net/Photos/Posts/gearonly.jpg)
At this point a couple of things became clear. First, with the oil slinger in place on the crankshaft, you can't see which one of the crank gear teeth is marked, and looking around the harmonic balancer at the crank teeth it can be a little tricky to determine which one is pointing straight up. You need to be able to see this because when you change the cam timing with this gear you have to rotate the whole cam gear to a new position, and the right tooth has to be pointing down at the crank gear tooth that is pointing straight up. Next time, I will add a dot of paint on the crank gear tooth so that it is more obvious.
The next thing that became clear was how nice it would be to have one of those Cloyes adjustable top cam gears, like the ones they make for other engines. Barry R is working on getting Cloyes to do one for the FE, and it would be so much easier to leave the top cam gear in place and just adjust the gear. But as it is with this setup the top gear has to come off and get rotated to a new position to change the cam timing.
I had learned on the engine stand that the pin that goes in the cam either has to come off with the gear, or come out first; if the gear is pulled forward and the pin stays in the cam, there is not enough slack in the chain to get the gear off. I put a vise grip on the pin and tried to pull it out, but it was stuck in place, of course ::) I left the vise grip in place in order to make sure that the pin came out with the gear, and managed to pry the gear loose with a couple of screwdrivers, as shown below:
(http://fepower.net/Photos/Posts/pullgear.jpg)
This really didn't take too long, but it would have been nice to just loosen the six bolts on the Cloyes gear and rotate the crank to get the cam timing that was required. Maybe they'll have that gear available in a few months...
After the gear came off the stub of the cam the pin can be pulled out, and the gear drops down into the timing cover as shown below:
(http://fepower.net/Photos/Posts/gear_off.jpg)
At this point the chain is not engaged to the crank sprocket, and you can rotate the upper gear to whatever position you want. I rotated it around to +6 degrees and pushed the cam sprocket back onto the cam, after making sure that the tooth marked +6 was pointed straight down. Looking through the pin hole in the cam sprocket I could see that the crank was going to have to be rotated somewhat in order for the pin to line up, so still gripping the pin with the vise grips I pushed it into the hole and then rotated the crank with a wrench while pushing on the pin. After what I assume was six degrees, the pin slipped into place in the cam.
I torqued the cam bolt to 60 foot pounds to make sure the gear stayed in place. Re-assembly was pretty quick; the whole process from start to finish took about 45 minutes. I warmed the engine back up and ran two back to back dyno pulls to make sure the results were consistent. Then, I repeated the process, retarding the cam by 6 degrees. But when I ran the dyno pulls this time, I got nearly identical results as with the cam advanced 6 degrees. I couldn't believe that this was accurate, so I figured I must have screwed up somehow. I pulled the right valve cover and put the dial indicator on the #1 intake valve to check the cam timing. It came in at an intake centerline of 98 degrees!
After a couple minutes I figured this out. There are 24 teeth on the crank gear. Therefore each tooth is worth 15 degrees. I had put the cam gear back one tooth off on the crank gear. This advanced the cam 15 degrees, but the cam pin hole I'd used was 6 degrees retarded. Advanced 15 less 6 degrees retard means an advance of 9 degrees; 107 was straight up, and 9 degrees advanced was 98 degrees.
I repeated the whole process again to get the cam timing right for the next test. This time, when I grabbed the pin in the cam gear it cam right out, and I was able to pull the cam gear off the nose of the cam easily. After re-setting the cam gear, I double checked the cam timing to make sure I had 113 for the ICL, then re-assembled the engine.
After warm up and two more back to back pulls, this time with more believable results, I ran through the whole process one more time to put the cam timing back where it had been initially. Again this time the pin pulled out easily and the cam gear came off with me just pulling on it. This time I changed the cam timing in 25 minutes. I got the same results with the cam timing in the original position as I had at the beginning of the afternoon, so right now I feel pretty confident in the results.
And the results are as follows: Advancing the cam cost a small amount of power all across the RPM range, but especially at the top end. Retarding the cam cost a LOT of power at the low end and midrange, but at 5800 RPM the 113 ICL started making more power. This part, at least, is more or less in line with expectations.
Dyno charts are below, with torque and horsepower on the same chart, and then also shown on separate charts. This engine has standard 390 rods with ARP bolts, so I don't want to run it past 6000 RPM, but I'm sure that the retarded cam would have looked better over 6000 RPM based on these results. I don't understand why the advanced cam didn't make more power down low, and maybe if I had advanced it less than 6 degrees it would have. But just based on the data I have, this engine doesn't quite behave in the conventional fashion.
(http://fepower.net/Photos/Posts/Timing.JPG)
(http://fepower.net/Photos/Posts/TimingHP.JPG)
(http://fepower.net/Photos/Posts/TimingTq.JPG)
Bottom line for me is that the timing cover can be used to change cam timing, and it seems to work on the engine just fine. Its not even that tough LOL! But you'll need dyno or track data to determine if you've moved in the right direction with the cam timing, because at least with this engine, it didn't quite follow the conventional wisdom...
Seems that the cam grinder had it figured out fairly well. It also seems that moving the camshaft only lets you know if you are getting the most of your combination, not make a huge horsepower improvement with the particular grind. On one 600+ci engine making over 1200hp, I only saw a swing of 6-8hp going either side of straight up. Confirms my testing. The cover definitely in a improvement for the weekend racer. Looks great. Joe-JDC
Has anyone ever run a timing belt on a conventional OHV FE?.....
Thinking belt drive could really shine on a cammer FE where weight and mass seem to take their toll as tests have shown.
http://www.hotrod.com/how-to/engine/ctrp-0809-beltdriven-timing-system/
Jay, what did the A/F ratio do when you advanced the cam timing? I've found here on some engines that the engine gets more efficient with the cam timing further advanced, to the point that jet has to be taken out. It would be interesting to do this cam timing change back to back in the car, just to get a feel of throttle response, although it would be a huge pain in the butt. LOL
I don't have your book handy Jay so I can't remember the specifics of your 428CJ. I'm curious where your DCR was at when you advanced to 101 ICL. Were you on the ragged edge of fuel tolerance?
Also..... You didn't mention it but I'm sure you had to adjust your ignition timing after each cam adjustment yes?
I like the nice beefy mounting face for the fuel pump. I'm looking forward to trying one of the timing covers out.
Here's the O2 sensor readings for the three pulls:
(http://fepower.net/Photos/Posts/Timing_lambda.JPG)
Seems like at the lower end advancing the cam wants to make the engine leaner,and vice versa at the top end. The flip is right around the torque peak. It definitely could go leaner up to 5700 RPM or so when advanced after the torque peak. Very interesting...
Kevin! You got me! I completely spaced checking the ignition timing after each cam timing change. How could I forget that?? But I did; I was in a hurry on Sunday :-[
I'm really glad you pointed that out; looks like I'm going to have to re-run this test. What a shame - more dyno pulls ;D ;D
I haven't calculated the DCR for these changes because I was running 110 octane race gas in the engine, and wasn't concerned about detonation, but I will look at that when I get a chance - Jay
Yep, that's about what I see. We have to pull jet out and I think it's because the engine is more efficient and is producing a stronger signal. You may be able to lean it up at the big end and gain your hp back.
You will need to nail down the ignition timing before making any other assumptions.
I have run similar tests about a million times using my belt drive on Engine Masters entries.
No combination reacts the same way. I have had some that were essentially insensitive.
And I have had some that really reacted strongly to changes. At least one engine wanted the cam timing advanced an incredible amount - ended up installed at 98 IIRC
If you chase this rabbit hard enough you will/might find that each iteration wants different timing and different fuel curves with cam timing changes. Its not really a change in signal (that variable is primarily airflow driven against the essentially fixed orifice of the carburetor), its the ability of the engine to consume the fuel it receives. Remember two things here - first is that the O2 sensor is reading the output - not the input of the fuel. Second is that an engine's power is the result of burning fuel - the more fuel you can effectively stuff down its throat and burn - the more power you will make.
Tuning is a two step process. First you gain control using the sensors and observations you have at your disposal. Then you tune for power - not for sensor numbers. You might discover best power with one engine at 14:1 A/F and have no signs of detonation. The next combo might want 12:1 and be speckling the plugs while doing it. This kind of optimization is lots of fun with EFI where you can snip together multiple RPM segments at different setting to chase the best possible curve throughout the chosen RPM band. And its the reason that an EMC effort takes literally hundreds of pulls to sort out.
I'm surprised you got the top timing chain sprocket off while the bottom sprocket was unmoved. :o
On my engine the timing chain was so tight they had to be slid on together when it was built.
Perhaps after it's ran a while it develops enough slack.
He pulled the pin out. Top gear should be able to be wiggled off if the pin is already out.
Jay, I gotta tell ya man, one of the big reasons that I like reading your stuff is that you tell it like it is. If you make a goof move (like we all do occasionally) then you tell us about it anyway. That honest quality seems to be quite rare in writer circles these days and, for me at least, is a breath of fresh air. That's why I bought one of the first run of adapters from you. I figured that anyone honest enough to show ALL of their work and not just the great stuff was someone to do business with. Keep it up Jay, I imagine that there are a lot of guys out there just like me.
BTW, just out of curiosity, how many of your books have sold now?
Made me think of the old SNL skit with Gilda Radner.
(http://www.sausedo.net/wp-content/uploads/2012/05/dirty-snow-rosanne.jpg)
In theory, the retarded cam will want (and bear) a little more advance, and the advanced will want (and bear) a little less. However, your test did the opposite without tuning.
I am not sure it will change things significantly with the small difference in ignition timing, but it will be neat to see if you have the endurance to do it again!
No endurance required, Ross, it was a pretty easy test :). I'm going to take my day off tomorrow and run it again...
By the way, I also have my doubts as to whether the timing change will have much effect.
Looking forward to it!
The old VariCam and Cam-A-Go (run by Henderson Power Sports at Engine Masters) both in their old fashioned/primitive ways they changed cam timing to maximize low end torque and maximize top end horsepower. Any way to dial-in determine/produce optimum Tq & Hp via cam timing?
The Ford Coyote 5.0 infinitely alters the cam overlap, cam timing, F:A, and Ign Timing simultaneously for optimum performance. No air-pump for the cats, it just alters overlap/cam positioning to add more air/0-2 into the exhaust
Found this on google along with an old post on the other forum by Qikbbstang while I was looking for info on the Varicam
http://nepis.epa.gov/Exe/ZyNET.exe/91006D4P.TXT?ZyActionD=ZyDocument&Client=EPA&Index=Prior+to+1976&Docs=&Query=&Time=&EndTime=&SearchMethod=1&TocRestrict=n&Toc=&TocEntry=&QField=&QFieldYear=&QFieldMonth=&QFieldDay=&IntQFieldOp=0&ExtQFieldOp=0&XmlQuery=&File=D%3A%5Czyfiles%5CIndex%20Data%5C70thru75%5CTxt%5C00000008%5C91006D4P.txt&User=ANONYMOUS&Password=anonymous&SortMethod=h%7C-&MaximumDocuments=1&FuzzyDegree=0&ImageQuality=r75g8/r75g8/x150y150g16/i425&Display=p%7Cf&DefSeekPage=x&SearchBack=ZyActionL&Back=ZyActionS&BackDesc=Results%20page&MaximumPages=1&ZyEntry=1&SeekPage=x&ZyPURL
Ran the test again today, with some help from my pal Steve P, and basically got the same results as before, despite the obvious timing change. I had thought about what I should see after the discussion earlier in the thread, and figured that with the cam timing changing +/- 6 degrees, I ought to see the same change in the ignition timing. I started off by running a baseline pull at the straight up 107 ICL position and 38 degrees total, then went to the +6 advance point of 101 ICL. Warming up the engine after the timing change, I ran it up to 3000 RPM and sure enough, the timing light said 44 degrees total! So, I dialed back the timing to 38 total, and ran the pull. The only real change was that I didn't lose anything at all on the low end of the RPM scale, just on the high end. After changing to 6 degrees retarded, 113 ICL, I saw 26 total with the timing light, which made sense because I had changed from 6 degrees advanced to 6 degrees retarded, while starting at 38 total. Again I adjusted the ignition timing back to 38 total, and got basically the same results as before.
Here is the data:
(http://fepower.net/Photos/Posts/tim_1.jpg)
(http://fepower.net/Photos/Posts/tim_1HP.jpg)
(http://fepower.net/Photos/Posts/tim_1TQ.jpg)
The curves are a little hard to follow at the higher RPM range, but I did an average calculation and from 5500 to 6000 RPM, the engine gained an average of 6 HP when the cam was retarded to a 113 ICL. So, retarding the cam definitely gave more power at the top end. I also ran one test to 6500 RPM with the cam at 113 ICL (fearing for the lives of my connecting rods LOL!), but right after 6000 RPM it appears that this engine has some valvetrain issues, because the power falls off and gets pretty choppy. So, I didn't bother to run any more tests at a higher engine speed.
A/F numbers also looked the same as before. Given how far off the timing was on my original test, I'm just a little surprised at these results, but in any case it appears that the original conclusions still hold. And it felt really right to start the new year, hearing a good FE on the dyno ;D ;D
The facts are that you still have a certain amount of lift, duration, and airflow that will only change to the average, not maximum. Finding where the car accelerates best with a given camshaft is what that ability to adjust the timing events helps to find the very most from a given combination. To gain more, a person will need to move up to more lift, duration, etc., to move the average airflow up the scale if you do not change heads or intakes. It all comes down to what your parameters for finding horsepower limits you to. Class racing, or bracket racing, or street/strip. The fun is in finding out the trends, and maximizing them to beat similiar combinations. Joe-JDC
While it may have only showed an average of 6hp difference across the upper range, it also was showing an average of 20-25 ft lbs torque difference across the bottom to mid range. That's fairly significant. And I'd have to agree with Joe, it's all about maximizing the combo. A careful evaluation of the data could also help tell you what the engine wants in terms of camshaft specs, helping a person to choose a different lift/duration spec to better suit the heads and intake. It could also help fine tune a combination where the drivetrain comes into play with tranny gearsets, rear ratios, traction issues etc.
I am surprised somewhat that the timing didn't make more of a difference. The more modern heads probably helped there. An old set of iron heads would probably have shown a bigger difference. Still good stuff. Thanks for all the effort, and posting it, Jay.
So the A/F ratio went rich again with the advanced cam timing?
I agree, retarding the cam caused a BIG drop in low end and mid range power. You sure wouldn't want to run that way unless you were only concerned about 5500 RPM and up.
Also, the engine has factory Cobra Jet heads, with a very minor porting job.
Yep, rich again from 5000 RPM to 5700 RPM with advance, and then once again it spikes lean at the end of the pull.
The old "boot heel" combustion chamber doesn't seem to care too much about ignition timing. Good stuff here Jay. Now we need a heart shaped combustion chamber to compare to. Wait a minute.... Didn't Blair just do something like this? ;) Lol
Boom-Zing it dawned on me that naturally an OHV motor valvetrain tries to retard its cam. The big problem with the VariCam and Cam-A-Go were they offered no way to adjust the ignition timing that was dictated by the cam/distributor and they were being backed off by the variable cam. The BINGO is a crank trigger eliminates the ignition timing being carried along by the variable cam timing unit.
Studying the VariCam I have to wonder if the "spring" that allows for the cam to retard by greater forces of RPM upon it, is subject to bouncing under the tremendous forces of driving a camshaft?
Very helpful data thanks Jay.
I ran these 3 in the Gonkulator, a couple guesses to dial in the base engine, then the Gonk said
107 ICL, 3 advance
Torq 487 at 4100
Powr 444 at 5400
101 ICL 9 advance
Torq 482 at 4000 down 5
Powr 425 at 5300 down 19
113 ICL 3 retard
Torq 467 at 4200 down 20
Powr 442 at 5500 down 2
Pretty close to what you saw except the Gonkulator didn't like the retard even at the top end.
I do find in the Gonkulator that the generalities hold in general, but as noted each combo responds differently.
I also find that 4 advanced is almost always optimum if the cam is well matched to the heads/manifolds.
If the cam is way too small, 0 advance or even a slight retard can work better. Just depends. :)
You have that 428 mule pretty much figgered out. ::)
As always Jay, thanks for all the effort.
Any chance of a head shoot out? Felony vs BBM...
I'd love to do the head shoot-out, Howie, but I don't have either cylinder head. Now, if I were to receive a donation... ;D
Diddo on what lovehamr said , reading these posts and your book and following your knowledge , along with everyone else s has helped in so many ways . I learn more every day , many many MANY thanks to you JAY . And for that matter everyone else as well .. Bud
