FE Power Forums => Private Classifieds => Topic started by: A4278V on October 15, 2018, 02:47:44 PM
Fe truck bells $80 Y block bells $95 small block bells $65 & up flywheels and block plates clutch forks also
loads of 50's-80's three speeds Galaxie Mustangs trucks and others $75.& up each
NEW Hurst Competition Plus ,Fairlanes Mustangs, toploader $500
USED Hurst Competition Plus ,Fairlanes Mustangs, toploader $355
units to take bolt on handles for other applecatiions kit cars Hot rods etc
Hurst Super Shifters for most top loaders $300
Mr, Gasket 4 speed shifter for Fairlane toploader $255
Hurst 4 speed shifter for Galaxie toploader$360
1963-64 Galaxie stick pedal assembles $200
1960-65 Falcon stick pedal assembles $155
1967-72 Ford F series stick pedals $200
1963-64 Falcon T-10 $500
thanks, Bruce central N.J. location a4278v@yahoo.com
1963-1964 Galaxie clutch pedal assemblies for $200: Are they worn and sloppy, or nice and tight? Thanks.
1963-65 Falcon toploader tail housing $255
toploader imposter 3 +1 o-drive trans $255
Factory shifter for above trans with Hurst like handle $125
1 short small block proshifted toploader twisted main shaft good gears missing tailshaft housing $400
Fe truck bells $80 Y block bells $95 small block bells $65 & up flywheels and block plates alco
Hurst t10 4 speed shifter for Galaxie $3oo
normal for a 100k car that was not abused needs bushings there is a hold on that set awaiting payment but there may be another set coming in
Galavie pedals are along with z- bars back in stock
still loads of stuff here thanks Bruce
I’m looking for a hurst shifter for a 67 galaxie with a bench seat, any possibility.
There is one for a 1965 with no handle it would work but not sure of the availability of a correct handle
still loads here Falcon tailshaft was sold along with the Galaxie pedals just in New Hurst install kits for toploader Falcons and Galaxies short Mustang bb or Fairlane tailshaft housings thanks Bruce a4278v2yahoo.com
more stuff in Galaxie & Falcon Hurst install kits along with the big and small block Hursts shiofters
