FE Power Forums => FE Technical Forum => Topic started by: CV355 on September 08, 2020, 11:46:54 AM
I upgraded to a rear sump tank and no longer have a need for the fuel pickup in the sending unit (except for supporting the float inside the tank). Short of simply crimping both ends, is there a more acceptable and clean approach to this? I thought of cutting the external tube about 1/2" long, crimping and soldering the end.
Any ideas?
I know they make copper caps all the way down to maybe 1/8, so if you didn't mind soldering that in place it might be a cleaner looking option.
I used a cap that came with a compression ferrel and used that to cap the line. Believe it was from Earls and I bought it from Summit, something like $8.00.
Greg
I like those ideas- looking into that route!
