FE Power Forums => FE Technical Forum => Topic started by: Pentroof on December 14, 2018, 01:02:30 PM
The packaging has gotten increasingly absurd.
Most recent box included several gaskets and full order of bearings. The box was huge, to accommodate the largest gaskets. I get that, but there was hardly any filler used, The boxes of cam, crank and rod bearings were floating around. On top of that, the rod bearing box was completely empty and the bearings were in a pile in the bottom of the box. Of course, this depends on which end you consider the bottom, but they were always at the bottom...meaning, I heard them before I opened the box.
On top of that issue, I can't find any material that would have been protecting the Speed Pro rod bearings when they were in the box. I can't remember what they use, but I assume there should be some sort of divider? Not to be found within the box or among the packaging. So, did a disgruntled Summit employee empty the box of bearings into the bigger box before taping it up and sending it on its way?
Frustrating. All the bearings are marked up from each other and I'll be sending them back. Luckily, I took pictures as I opened the box, because I could hear that they were loose.
I know what you mean with their packaging. It seems that the boxes from Texas are the worst. Everything is beat up, no filler material, the boxes are occasionally open. Surprisingly nothing is ever missing. Also, Texas doesn't even put packing slips with the order. Rob
I feel for ya, I do !
This summer I received a pair of 1020 Felpro head gaskets from Summit, and upon opening the box I'd bet they woulda fit a rotary 4cyl airplane engine --jk, but you get the idea. Around that same time I received a pair of spendy header gaskets, this time from a 'ma and pa' type online speed-shop, packed in a too-small triangular tube --oh yes, cousin Darryl decided they'd fit right in if he kinked them longways and voila, in they went. :-[
All parts were returned and not harmed any further in the telling of this story. I did finish it all without much further ado, The End ;D
ps: I did keep the scant bit of bubble wrap for my needed therapy session, lol.
JEGGGGG's. LoL
I know they can't stock every part in the world, but after a month of daily slips to my EFI delivery that pushed out to late January now, I gave up on Summit and had Brent get it for me.
You'd think a company like Summit would have every wholesaler in their back pocket, but they couldn't make an EFI system delivery happen. On the good side though, the original deal had a free air cleaner in the deal, which they shipped and told me to keep. Not a windfall, but hey free is free :)
Try to live on the end of the line like i do.
I get sent to me the junk others have rejected
and sent back. Oooh hold your horses dont throw
that away, send it to Sweden to much trouble to
send it back, so he keep it and fix it >:(
And thats not just Summit
I haven't had much trouble with Summit, but 90% of what I order comes from the Nevada warehouse. I have noticed they aren't using nearly as much packing filler, but anytime I've ordered "delicate" parts they seem to have extra filler. I'm sure my luck will run out sooner or later. I will say this, Summit has always taken care of any issues with damage, wrong parts, etc. whenever I've had any. There is no doubt that the last year or 2 their customer service has noticeably gone down hill. I'm just lucky I haven't had any real problem yet.
Lately it seems like Speedway has been pretty good about instock and quickly shipping, but they tend to be a little higher priced and for me it's easily a week to see anything from them if it's in stock, 2 weeks if not.
Not really Summit or Jegs fault, but I'm less inclined to buy from them now that they started charging tax. I understand that it isn't their fault. The thing is, at least where I live, the State has been so unreasonable in respect to taxes and regulations for small businesses that all the speed shops I used to deal with local essentially got driven out of business. Now the State is forcing online retailers to collect tax under the guise of being "fair" to brick and mortar businesses that their unreasonable taxes forced out of business in the first place.
Speedway is a good company, they are about an hour from me and really easy to work with.
Not that Summit and Jegs aren't too, but like you, if tax comes into play, why not buy where I can go grab the parts and look at them?
If you ever do a mail order from Advance Auto or Autozone though, THAT'S where you get to see some lazy packaging. Same deal as the original post, loose stuff, folded stuff, I don't even bother
WORST packing job I've EVER seen was from Rock Auto. I bought 2 brake drums for my 73 F350 dump truck, no one had the F350 drums in stock locally.
They packed both of them in a one flimsy box and threw in about 10 old D-cell batteries. NOT kidding, no other packing what-so-ever. I'll see if I still have the picture from that. It was a pretty epic packing job fail. They did take care of the issue and sent 2 more drums out.
alot of it might not be summits fault.my son worked for fedex for a few years and he told me some of the dock workers and warehousers were rough with packages.they throw them around like they dont care whats inside.i have seen well packed stuff get busted open.
I know your pain Heo. Sweden must be like Australia. Send any old crap you find on the shelf. It's only $400 in freight, no problem.
After paying over $1400. canadian for a set of hooker headers from summit for a 69 fairlane with a fe. We waited for more than a month and a half the box finally arrived here in northern ontario. We opened up the hooker box and found a scrap 69 fairlane fe header. The tubes stuck out a quarter inch past the mounting flange. For the drivers side they actually sent a shorty header for some type of small block chev.
Called summit to return at our cost then almost two months later another box show up from summit. They sent the exact same headers that were no good the first time right down to even the same shorty header.After sending the box back again... four and a half months later the real set showed up.
Let me tell you guys a good one. About 3 or 4 years ago my wife asked me what I wanted for Christmas. I usually tell her
something I can use in the garage or on one of my vehicles..
I have a Quicktime bell I bought from Barry several years ago. It's one without the starter cover, so I told her I needed that cover and
Jegs had them for $39. She ordered it for her parents to give me and had it delivered to their house so it would be there for Christmas day.
Christmas day at their home I had this big heavy box under the tree and when I opened it there was a complete Quicktime FE bellhousing.
My wife noticed the shocked look on my face and she said she ordered the starter cover and this is what they sent.
I called jegs and told them about the mistake and they arranged for FedEx to pick it up at my house and said they'd sent me the cover. So about a week or so after they picked it up FedEx showed up with a big heavy box and it was the same bellhousing ;D.
I called them back and tried to explain it to them to no avail. So I have got a complete bellhousing for $39. I think they are $800 plus
now.
Sometimes the mistakes end up in your favor sometime not.
garyv
I stopped ordering from jegs long ago--they NEVER got any of my orders right. I swear, it was like going to some fast food drive through where they aren't capable of pushing the button on the register that has the correct product photo on it, since having words on a register is far too confusing. I often suggested they write everything in crayon or sidewalk chalk, then they may understand. Once again, the dismal tide rears its ugly head.
I only use Jegs. Had a problem I ordered the wrong rim and mounted a tire on it they told me to be careful and dismount and send it back they will look at it. A week and a half later got my refund. Granted I spend a lot of money there between my dad and me but they took care of it.
I got one of those "what were you thinking??" packages once. Arizona Steve had a super rare swing-away dash and steering column setup for a '64 Galaxie. I plunked down some good cash and waited expectantly.
The FedEx guy arrived and he did not look happy. It took two of us to drag the box out of his truck. The box (made out of two slid together) was falling apart and dirt was pouring out. Fortunately the delicate dash trim was decently wrapped up and no worse for wear. There must have been two pounds of authentic AZ dirt cushioning that dash and steering column!
In the end, the setup is fine and usable with some TLC. The FedEx guy did not like me for awhile after that.
Lol, dirt as a packing device. Brilliant, kinda.
So you guys are actually getting parts? I have had retainers on order for nearly two months, valves on order almost as long. No shipping date, but they have my money. Joe-JDC
Texas shipping is the worst for me also.
I use lane auto in SW lower mi they cost a little more but are 70 mi from me they ship also.They are part of motorstate a big warehouse i think they run 6 trucks to Canada and many to the states every day.I know a lot of engine shops get speed parts from them a few years ago I went and got a set of edelbrock fe heads they had 8 sets in stock.
Well I think just about everyone is suffering right now and much of it can be pointed back at USPS and UPS , fed ex so far has been pretty good. In this area anyway if a postal worker coughs they are off for 14 days with pay.... This area being what it is there is a ton of coughing going on....
Its frustrating for us as the end users but I cannot imagine these business owners are none to happy either not being able to get their goods to consumers. Also there was a huge wave of refunds for parts that never made it to the destination nor were returned to the origin....
Ive got a few things from Brent that were cross shipped and they actually showed up quick... Its a crap shoot...
I hear your pain Heo & Stubbie!
In 2016, I bought a set of Borla ATAKs for our GT500 from American Muscle. I had been a customer of AM for years, loved their prices and customer service. The delivery day came and went, no delivery. I called UPS, they said they could not locate the package. It showed up a week later, literally thrown against my garage door (dented the door and trim), and the box was a disaster. The box was the size of a dishwasher, shredded and held together by 3 or 4 different types of tape. It looked like it was packaged horribly, fell apart on a UPS truck or something, maybe tossed down the Grand Canyon, and someone decided to tape it back together. The mufflers were dented all over, one flange was bent inward. AM wouldn't take a return, UPS refunded shipping but since it wasn't insured (not sure why), I was stuck with them.
I have always been happy ordering parts from Summit, but this whole Covid fiasco has messed up delivery of products all over. I have the seats for my 59 sitting at an upholstery shop, coming up a month, still waiting for the material to show up, something that normally took a few days, pre Covid. He also has a 67 S396 Chevelle in his shop, all apart, waiting for the headliner and seat covers that were supposed to be in stock at the manufacturers warehouse. We are in Eastern Canada, and my seat material and the Chevelles interior pieces are in the US, but my upholstery guy said getting deliveries in Covid times has been very hit or miss, and winter likely hasn`t made things any easier.
my problem is with the brown trucks,got a 20 or so parts order,when the driver brought the large box out the front door of his truck he dump it and most of the contents on my driveway.he didnt see my as i was outside when he did that.so i took inventory while he waited fortunately nothing was missing and everything was packaged seperatly. now most orders come from the other service.
i have always gotten my packages from summit.i have received extra parts before.i placed a order,got tired of waiting,sent messages of complaint and i got my package a few days later and about a week after that i got another one free.
I'm lucky, Summit is a 30 min ride. Order, go to pick up and inspect on site.
UPS has obliterated more than a few things of mine over the years. My wife works in logistics and tries to avoid UPS as much as possible- she says "they always figure out how to trash everything."
Received a package a while back from Amazon. Don't remember what it was but it was something small and light. Came in a huge box. Only weight you could feel was the box. Made a comment to the UPS driver. He just laughed and said "that's Amazon". On the other side, I wanted to buy a nos plastic dash from Greensales. They wanted to ship it freight. Shipping was as much as the dash. Told them to keep it.
I ordered a Fluidampr for a 3406 Cat and Summit had the best price but only in stock at the Texas warehouse. They're a bit over 500 bucks and they shipped me 5 of them before I got one that wasn't dented or missing something.
Nevada has been pretty good.
Maybe I spoke too soon.
FedEx freight showed up today with a C6 I ordered from Summit (long sad story about being in a hurry and then getting shafted by the trans shop) because they sell them outright with no core.
Shows up in a cardboard box with no packing material at all and the entire thing was sitting on a pallet with no banding/straps of any kind!
