FE Power Forums => FE Technical Forum => Topic started by: fe-starliner on October 01, 2020, 09:36:09 AM
My friend Bill, who is a Ford guy and has owned several FE powered cars in his 68 years, has almost completed his build of a 300 Ford six with turbocharging and fuel injection. He's searching for info on a good spark plug to use. I've told him of the good help and information always available on this site (he's not a member of any forums) and he asked me to post this. Of course it's 18mm with the iron Ford head. Any turbo guys have suggestions I can relay to him?
Thanks.
The old Autolight 124 isn't a bad place to start. Might need to tighten the gap just a little.
A couple non resister options, NGK A6FS or colder yet with more tip projection AP7FS. Probably want to stay with a resistor option with the fuel injection system.
Can't get the AR6FS anymore.
I'm sure there will be more replies from people more knowledgeable than me on spark plugs.
thanks BigBlueIron, I'll relay the info to him.
Denso makes a copper u groove plug like accel i have had good luck with them rock auto has them at 1.34 each.
My iron headed 2.3 turbo runs the NGK version with a heat range of 7 on E85
Depending on fuel that might be a decent starting place
Feel free to ask if I can help I will
Dave
E85 can tolerate a hotter plug as well as ignition timing close to naturally aspirated. If this gentleman is not running E85, I would start with a #9 heat range and go from there.
Thanks everyone for your replies. I have forwarded the info to him.
