I hadn't intended this be only about FE's, that's why I put it in this section but, I'm happy to have FE info.
Brent, could you give the rpm of the 810 ft lb of torque and explain this a little more?
"I use wider LSAs on my FE hydraulic rollers because aggressive lobes cost hp with heavier valvetrain."
The only difference that I can see, between the FE and say a Yates or SB2 engine, is the length of the push rods but, there valve stems are longer than most FE's. Now a days there is really no reason for the valve train, to be any heavier than a NASCAR engine.
For street engines, because of the length of the valves and expense to replace them, I can see people keeping the 3/8 valve stems but, for anything else, 5/16 or 7mm valve stems would be more desirable.
I was also hoping to get input on SBF, both W&C. I'm not a canted valve guy but, with that type valve angle, the flow is not as direct from the intake to the exhaust. That being one of the big advantages of the hemi and 4 valve, pent roof designs.
The race engines that I ran, where of the latter design and we ran 102 lsa on those, at 8500 - 10,000 rpm.
The last I new, the canted valve, NASCAR engines were running 106 lsa at 9,000+ rpm but, 106 lsa has been standard for more than 40 years in both, Ford and Chev wedge & canted engines. One cam maker, John DeLong, promoted 108 lsa for short track engines, over the 106 lsa, that was univeral. Presumably for a little more torque, exiting corners. I sponsored a a car that used his cams. He was one of the great, early cam grinder and made a gear drive, that I liked, too.
Increased vacuum is not what I submitted this thread about. What I'm interested in, is how to pick up torque, using lsa, between the max torque and max HP in the top 2000-2500 rpm range, whether that be 6,000 or 10,000 rpm, as that is where it counts, in race engines.
