What happened to ported C1s? They'll outflow the Edels by 40 cfm. I like Edel heads, just wondering why the change?
- I don't think stock head bolts will fit, or in the very least I do not think you can get a socket on them. I'd go aftermarket with a washer.
- You can run the stock rockers, but not sure what pushrod length you'd need AND you'd need to run stud kit, you can't use the stock length rocker stand bolts
- All the sets I have had come through were slightly larger than advertised, all were above 74 cc
- I don't see any issue with the head gasket you want, assuming the block is decked for a nice flat surface
I would check installed heights and spring pressures though, I have seen Edels come with some stout springs, hate to see you eat a cam
