FE Power Forums => FE Technical Forum => Topic started by: Jim Comet on December 31, 2019, 10:58:13 AM
Hi guys, I have been looking for urethane leaf spring bushings for my 1966 Comet. The front should be a 2.04 inch od and the rear should be 1 inch od. I have found the fronts with the wrong rears and the rears with the wrong fronts. I'm just trying to avoid buying 2 sets and wasting the extra parts. Thanks, Jim
Jim ,
The fronts are all that is needed. I use the stock rubber bushings in the rear.
I just found them on Energy suspensions site listed as individual parts in their universal parts section. Randy, thanks for the reply. They have the rears so for 15 bucks I will throw them in. The 10 inch slicks are going to be a tight fit, so the tighter the suspension, the better. Jim
